Simple - how can this be fixed?
I know only the odd few 306's were fitted with these - are they easily replaceable? It's for a phase 2 DT if it makes any difference?
Cheapest place to get hold of one.
Any extra information on these would be grand!
did it fail because it is siezed?? i just sprayed mine with aload of wd40 and worked it in and has been fine since.
yeh - linkage seized - how do i go about loosening it up??
Sorry, never come across this - all the frenchies i've worked on (giggedy)
spray it with WD40 and work it then more WD should be fine then
(22-02-2013, 05:15 PM)karl1989 Wrote: [ -> ]spray it with WD40 and work it then more WD should be fine then
Work it? Manually move it around? or does it move under brake load?
Yeah ph2s have them.
Simples. Unbolt the arm end from the beam and cover it in some WD40 and work it free and refit. simples. Ive never seen one yet that has been too buggered to not be repairable.
As said spray it with WD and work it up and down with grips
(22-02-2013, 05:21 PM)Niall Wrote: [ -> ]Yeah ph2s have them.
Ok i read this and think you're talking about taking beam apart /facepalm
Is it fairly straight forward when looking at it??
yep. just unbolt one end of it and work it free. Could try a bit of heat on it as well if really needed (although i doubt it) but be careful.
Personally, id just cover it in WD and work it free.
what exactly moves? i've only seen pictures of it - the spring??
There's a shaft that goes through the spring and then goes through the bit that should move. It's had to explain but you should see the bit that it pivots on and that's the bit to spray with WD
That's the bit you need to free off
yup...happens all the time.
thats one lazy ass MOT tester though...at the pug specialist I used to work for, the MOT tester would just spray it on the ramps and work it free there and then. If no one has weight in the back often then they just seize!
FYI...my ph1 has brake a rear brake compensator
I free them off as long as that's like the only thing it fails on
I just spray with plusgas and hit it with a hammer lol
Can you remove these? Being lowered i dont see the point in it as it will always think i have masses of weight in the back.
Yeh but it compensates for that! It's what it's there for
(23-02-2013, 12:12 PM)Frosty Wrote: [ -> ]
Great picture! what way exactly is this moving - stretching or compressing that small spring? soaked it up today and no movement at all
the bit that my finger is pointing at should move towards the spring. i find the best way to move it is mole grips or pry it with a big screw driver
set of grips on it and move it too and fro until free...
altho now probably not main priority!
(23-02-2013, 11:16 PM)Piggy1987 Wrote: [ -> ]set of grips on it and move it too and fro until free...
yep, the Dturbo still needs sorting as it's for the MOT - only got 2 weeks to correct it for a free re-test.
I'll have another crack today.
