So today I decided to take the car for an "enthusiastic" drive and nearly lost it completely.
Literally the car will hold grip and then the back end will go.
Have just had the MOT and new tyres all round.
Any ideas?
How many miles have you done on the new tyres? What are they? If that's all that's changed and you haven't driven much they'll need to bed in...
Other than that, the usual beam mounts etc.
Around 350 miles on the tyres since new,
Any way if checking the mounts?
is the beam tracking ok? mounts good?
tyre pressures ok?
what make of tyres?
Are you sure that there isnt diesel leaking out of the tank onto the back wheels?
How hard are you driving! Do you feel the point at which it lets go?
(19-02-2013, 07:22 PM)Jtrigga Wrote: [ -> ]Are you sure that there isnt diesel leaking out of the tank onto the back wheels?
This would make sense, I have a diesel leak from somewhere.
Also unsure on tyres, budgets probably though
(19-02-2013, 07:26 PM)Jonny b Wrote: [ -> ]How hard are you driving! Do you feel the point at which it lets go?
Not VERY hard, and no it literally just let's go
if its properly slippy it could be diesel! If not then shagged rear beam mounts would be my bet. Heard of a few people losing it because of them!
How can I check beam mounts?
budget tyres would explain it for me
if the tyres are only on 350 miles, you should really be scrubbing them in for about 500-750 miles.
Anyone else thinking, stop lifting off?
(19-02-2013, 10:10 PM)sammy9212 Wrote: [ -> ]Anyone else thinking, stop lifting off?
It did cross my mind
Spec 2s for £166 for all four corners
Okay, we'll I'm pretty sure I know how to drive first off..
The car has been holding my driving perfectly well until last night when this started happening.
Spec 2s for £166, Say no more,
This started happening my car recently too, doing 70mph in a straight line is dangerous the car starts swaying as if it has a flat tire.. Was thinking beam mounts myself and as above is there any way of checking them without taking them out?
(19-02-2013, 10:54 PM)David Wrote: [ -> ]Spec 2s for £166 for all four corners
I'm looking for tyres for when I put cyclones on where's these tyres from at that price?
Can't fooking stand Spec 2s!
Crap sidewall, shit in the wet, don't last...
At the end of the day they're a BUDGET tyre and you can feel it on the road - I'd never put them on unless I was doing a track day and I had money to piss up the walls and see off a set in a few hours.
(20-02-2013, 12:49 PM)Ruan Wrote: [ -> ]Can't fooking stand Spec 2s!
^^this.
Just wondering though Dec.......
Did you have a girl in the car? did you use the hand-brake? If so, It wouldn't surprise me if that made her so wet it spilled out of the car, onto the road, and you lost the back-end........
/topgear
Jack the car up so the rear wheels are off the ground then see if the beam drops or moves
(20-02-2013, 12:32 AM)Bananalad Wrote: [ -> ]This started happening my car recently too, doing 70mph in a straight line is dangerous the car starts swaying as if it has a flat tire.. Was thinking beam mounts myself and as above is there any way of checking them without taking them out?
Check your rear wheel bearings dude one of mine gave up the ghost on a driveback from burnham to brum at first felt like crosswinds then bout 70miles later it felt alot worse pulled over atthe services n check the bearings, not good to say the least
I had a bad experience like this. back end styley to find out my rear shock bolts were loose
Wasnt nice!
mine does it but i have 2 good tyres on the front and 2 budgets on the rear...... But thats how i like it lol works well with the torque of a weasle
On the spec2 subject as soon as they see moisture they're wank. Michelin PE2 ftw! Maybe if you were in a hotter country spec2s would be ok but here where we get 2 days of sun a year.... f*ck that.
