17-02-2013, 02:10 AM
17-02-2013, 08:46 AM
Thats something you'd have to find out buddy, if you get all the bits to convert it then i see no reason why not, Peugeot after all kept all the plugs on.
17-02-2013, 05:39 PM
As rich says most of them have the wiring in there already. They have most extra wires for other goodies. Saves costs having to make different looms so it *should* just be plug and play. Just get electric mirror and switch
17-02-2013, 05:46 PM
or possibly may have to change inner door looms and get electric mirrors just pop the manual mirror cap off and see if theres a thin bron plug behind there if there is then your laughing all you need then is window switch with mirror adjuster and the mirrors.
17-02-2013, 11:40 PM
cheers guys, will have a play and see what happens, worst case is i sell on what ive bought and leave it at that, last question, do the electric mirrors fold inwards? some Tw*ats broken mine buy pushing it all the way back...
18-02-2013, 12:25 PM
I tried to do this conversion, I changed the mirrors, switch and inner door looms but it still didn't work, turns out the door to body loom didn't have the wires.
But yes both sets fold forward
18-02-2013, 10:35 PM
(18-02-2013, 12:25 PM)londondan86 Wrote: [ -> ]I tried to do this conversion, I changed the mirrors, switch and inner door looms but it still didn't work, turns out the door to body loom didn't have the wires.
If this is the case, it shouldn't be too hard to wire in a common live feed to the switch.
19-02-2013, 07:57 PM
(18-02-2013, 10:35 PM)Rich306 Wrote: [ -> ](18-02-2013, 12:25 PM)londondan86 Wrote: [ -> ]I tried to do this conversion, I changed the mirrors, switch and inner door looms but it still didn't work, turns out the door to body loom didn't have the wires.
Is that all that's needed? What about the mirror on the passenger side, I assume there must be around 4 signal wires goin to it.
28-02-2013, 01:47 AM
Cheers for the comments, went out and bought a set of standard manual ones, had them on a week and the passenger one has already been broken by people folding it the wrong way constantly!!
28-02-2013, 08:20 AM
So you have manual windows in your ph2 dt?
28-02-2013, 09:03 AM
electric door mirrors use 4 extra wires through the door loom plug
pins 7/13/14/15
12-03-2013, 08:50 PM
(28-02-2013, 09:03 AM)cully Wrote: [ -> ](18-02-2013, 10:35 PM)Rich306 Wrote: [ -> ](18-02-2013, 12:25 PM)londondan86 Wrote: [ -> ]I tried to do this conversion, I changed the mirrors, switch and inner door looms but it still didn't work, turns out the door to body loom didn't have the wires.
pins 7/13/14/15
Thought this was the case, cheers Cully!
