Guides
Threads
- Guide: Front suspension/spring/coilover change (72 Replies)
- GUIDE: Sticker Bombing (29 Replies)
- Sack off your auto adjuster on your clutch cable (BE3 Pull type) (3 Replies)
- How to Remove a HDI Inlet Elbow (25 Replies)
- Ph2 IR central locking conversion to RF (59 Replies)
- GUIDE: Fitting Upper & Lower Strut Braces (39 Replies)
- BOSCH VE GUIDES - 11mm Hybrid Bosch Pump + Gov Mod (20 Replies)
- How to clean intank strainer/filter (D turbo) (24 Replies)
- Guide: Centre console facia removal (10 Replies)
- Reprogram a key fob (106, 206, 306, 307, 405 ,406 ,605, 806) (4 Replies)
- Resetting your ECU (HDi) (7 Replies)
- GUIDE: Dual Horns (50 Replies)
- Hdi Lift Pump Upgrade (Pics/Tips inside) (24 Replies)
- HDi cover mounts...fix :) (14 Replies)
- Glowplug Light Mod (18 Replies)
- Track Time @ Castle Combe (9 Replies)
- exhaust gas recirculation Valve removal EGR (70 Replies)
- GUIDE: Dewipering (65 Replies)
- Guide; De-Locking Your Boot. 56K NO NO (29 Replies)
- Galletto 1260 Guide (10 Replies)
- TU tappet adjustment (3 Replies)
- Lowering engine fan kick in temperature (11 Replies)
- Synchrometer Instructions (0 Replies)
- Pre-track checks (11 Replies)
- Lowering rear suspension (8 Replies)
