Head gasket list - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Other Marques (https://www.306oc.co.uk/forum/forumdisplay.php?fid=38) +--- Forum: Technical (https://www.306oc.co.uk/forum/forumdisplay.php?fid=40) +--- Thread: Head gasket list (/showthread.php?tid=28056) |
Head gasket list - Nathan1305 - 30-11-2014 So going to be doing the head gasket on the 106 and there's a small oil leak coming from it. I've got a list of the only things I can think of. - Head gasket - head studs - cam belt - water pump Do I need anything else? Thank you guys RE: Head gasket list - Piggy - 30-11-2014 Head set...for other gaskets and seals etc Coolant perhaps Engine oil/filter Check ya aux belt too...maybe worth doing RE: Head gasket list - lolsteve - 30-11-2014 hheeellllooooooo did someone say headgasket RE: Head gasket list - Nathan1305 - 30-11-2014 (30-11-2014, 10:05 PM)Piggy Wrote: Head set...for other gaskets and seals etc Awesome do you think the head will need skimming? (30-11-2014, 10:20 PM)lolsteve Wrote: hheeellllooooooo did someone say headgasket Haha genuinely made me laugh RE: Head gasket list - Piggy - 30-11-2014 Get it checked. If its not overheating and you remove it cold it should be fine though RE: Head gasket list - Nathan1305 - 30-11-2014 (30-11-2014, 10:29 PM)Piggy Wrote: Get it checked. If its not overheating and you remove it cold it should be fine though Yeah it's not over heating at all and only a tiny bit of Mayo and a bit smokey so it should be fixed with a new gasket and all the fluids drained and changed? RE: Head gasket list - 306Dan - 30-11-2014 I'd take it to an engineers to have it checked my local one doesn't charge for checking just skimming RE: Head gasket list - Nathan1305 - 30-11-2014 (30-11-2014, 10:55 PM)306Dan Wrote: I'd take it to an engineers to have it checked my local one doesn't charge for checking just skimming Cool there's a highly recommended garage by me so I'll take it there and get it checked out RE: Head gasket list - Norledge - 01-12-2014 TBH those 8v TU's take a LOT of punishment, I've never NEEDED to get one skimmed, but if it's going to take some serious abuse it may be worth it. I love these engines in these cars, I've managed a head gasket on one it 45 minutes before now (just ask Ruan!) RE: Head gasket list - Ruan - 01-12-2014 Easiest head gasket change in the world... But yeah, if it's been overheated badly it'll need a skim, if it's not overheated, you'll probably be OK! RE: Head gasket list - Nathan1305 - 01-12-2014 (01-12-2014, 08:17 AM)Norledge Wrote: TBH those 8v TU's take a LOT of punishment, I've never NEEDED to get one skimmed, but if it's going to take some serious abuse it may be worth it. (01-12-2014, 11:56 AM)Ruan Wrote: Easiest head gasket change in the world... Awesome thanks guys yeah the temp sits just under half way even when giving it some so it should be fine, hopefully there's a thread on here or 106oc on how to change one, never attempted it before RE: Head gasket list - Norledge - 01-12-2014 1. Unbolt exhaust manifold from head 2. Drain Coolant 3. Unplug Fuel Pipes/Wiring loom 4. Remove top Cambelt cover 5. Release cambelt tension 6. Undo headbolts Literally that simple! RE: Head gasket list - Nathan1305 - 01-12-2014 (01-12-2014, 01:55 PM)Norledge Wrote: 1. Unbolt exhaust manifold from head Oh haha that's made this job a whole lot nicer. I think I'll enjoy doing this |
